Lamba question??
Car  Rb 182
I have a Decat sat around so thought I might fit it,
I was just going to bung up the second lamba Hole n leave lamba hanging over heat shield??
But was wondering isit worth replacing the front lamba as IV heard if you have a bad reading front lamba it can put your car into limp mode???
My average miles per gallon is around 30??
Thanks for any help :)
you can get a fault code on your dash, personally I wouldnt fit one as I wouldnt want to mess with the engine fault codes! Also sure MOT's are going to annoy you now ?
Personnaly i wouldnt bother with a decat but if i did i'd just put up with the light on my dash / or get a OBD fault reader for £20 and turn it off whenever it came on.
I wouldnt bother replacing the front one unless its knackered TBH - in which case you would be having running issues i would have thought.
