Lamba thread size,
Car  Clio 182
Quick question what is the lamba sensor thread size.
Cannot get my sensor out of my cat so going to just bung the decat hole.
If i can get it out am i best to fit it to de cat or just cable tie it up behind heatshield?
I'd bung the hole and tie the sensor up, pretty sure I've got a couple lambda hole bungs in my tool box. Easy to get and pretty standard size across most cars
Blow torch. I used one from b&q, heat outside of where the thread area would be till it's almost literally red hot and then spin that b**ch off.
Pain in the tits but worked for me. The torch has paid for itself tenfold since, being used no end of times on other ceased stuff!
Id probably just get a proper bung and then bag up and cable tie behind heat shield as you've said.
