lambda issues????
Car  Phase 1 Clio 172
hi, my post cat lambda is shot and the wires have snapped rather than buying a new one to plug in and tie up out of the way to turn the light off, can i re wire the the lambda loom and possibly put a resistor or something along those lines in to trick the ecu in to thinking the lambda is in and ok as £80 ish pounds to just tie it out of the way is a bit steep? all help will be greatly recieved thank you
