Lambda Sensor, Emissions Light On From Decat...
Car  Coiley'd Clio PH2
Basically, is there a way i can get the emissions light to turn off?
Having a De-Cat, its on all the time...
Im guessing you could take out the bulb on the dash or cover it up, but i have read somewhere that you can buy something that fits onto your lambda sensor so that its tricked into thinking your emissions are within the limit?
take the sensor out, leave it plugged in, and tuck it up behind the heatshield in the tunnel. You will need a bung or an old sensor to plug the hole
