Lambda Sensor - ph1 172
sorry im massively confused now, on the ngk partfinder, when you chose the front sensor it shows a wire length of 455mm, yet when you chose the rear position it shows the same connector only with a length of 380mm - surely thats back to front?
Bosch also seem to operate a similarly backwards system on their catalogue.
Just a case of get the longest one and cable tie the b**ch out of the way?
