Lambda Upstream and downstream voltage values
  Clio 172 Ph2
I'm after the Upstream and down stream voltages for the lambda sensors.....
getting a slight miss fire every now and then
Clip is showing a small amount of missfire correction and the voltages are
Upstream fluctuates as it should at various throttle openings
Downstream fixed at 0.412v.......my guess fubard?
Downstream is ok. Nothing to do with engine management. It's only there to check the catalyst function and trigger the EML if not. Sprak plugs fine? Coilpack and leads ok?
