laptop based diagnostic software
having been into vauxhalls all my life i purchased an obd port lead and relevant software for my laptop to reset airbags, read fault codes etc.
now that i have 3 renaults and there are another 4 in my family i want to get the same stuff for them. i paid £40 ish quid for the lead and vauxhall software so would like to spend no more than that.
what do you folks recommend ??
is your airbag light on then? mine was and was told to fiddle about with the wires under the drivers and passengers seat and it went off, or has your airbag gone off? lol
ive been fiddling like ive never fiddled before lol !!!
i want it for other stuff in the future not just for the airbags at the moment. the vauxhall stuff ive got is ace. it shows real time engine data and sensor readings. so if a sensor is dodgy but not showing as a fault on the ecu you can check things are running spot on and within acceptable parameters.
Forget about it, the only thing that will do everything is the renault clip system. Got a few £k spare?
What he said.......
You can mabye clear the lights/fault but it will still be in the ECU until a Renault Clip tester is used.
The rstuner can read/erase the stored faults in the ecu and the ones that appear by the electric fault warning light not the obdII warning light. But you can't do all the configuration stuff you can do with clip, it can change stuff on the whole car.
it sounds as if he's askin what " after market hand held tester " is best to use ?? we all no the reno clip is the only one to every thing, but if its just erasin faults an reading live data etc some of the testers on the market now do it.
