Bus Winker
While I was fitting my new ball joint last week I had the shocks and ball joint disconnected so the drive shaft came out and oil started leaking quite badly.
It also seems to be leaking quite alot once the shock and ball joint were back on.
Does anyone know what could have caused this? Is it the rubber that has come loose or a more serious problem?
Also, if it is the rubber will I just need to reseal it and what oil will need topping up?
I posted this in my original thread about the ball joint but I thought a new thread for this problem would be better.
Also, I'm going to pick up a decent jack and some axle stands at the weekend. Can anyone recommend any?
