for those interested here is a few pics i put together for another cs'r
because of this beauty
i have had to sit my spare wheel on top of my lpg tank
so with this limited room i came up with a plan for better sound in my car
cut a piece of mdf to sit in the bottom
also have two pieces of wood (roofing lats) going across the back, fastened to the isofix bar
i then made a bit of wood for one side
then made sub box out of mdf (sealed it with silicone) the correct size to fit under floor
then of course there is the lid for the spare wheel side and a little bit extra down the side to fill gap up, i made the lid so that when i lift it up it jams againt the bit the parcel shelf rests on
carpet is autoleads grey, can be bought from halfords or motorworld etc, as mentioned in a few threads its best match to clio boot around
i then cut out a hole for sub
then fitted a metal speaker grille sourced from ebay :approve:
if you take your time and measure stuff properly its a doddle
bosch jigsaw used for cutting wood
staples stapler used to pin carpet down, should be glued like but MEH
and further questions feel free to pm me
(please note that these pics are not in order, as my boot build went through several stages but this is as close as i can get to a straight through guide)
hutchie
hutchie
