Light problem!!
  PH1 WANTED
I brought some lightbulbs a few months back and one of them has gone. I went to change it tonight and it has melted the light bulb holder!!
I have no idea how but it now won't work at all. How can this be fixed??
  Toyota MR2 GT Turbo
Solder the connections on the bulbholder back together?
Or get a new bulbholder on its own, only like £5 from the breakers.
Did you get the wrong wattage bulb or something?
  PH1 WANTED
The bulb that is broken is the dipped beam (the main driving lights). I have the right bulbs in. The holder is seems to hold the bulb but is a bit melted. I've trieda new bulb bit it doesn't work.
Sure you didn't put 100w instead of 55w?
I hear they melt the wires after time
If not you probably bought some s**t bulbs
  Toyota MR2 GT Turbo
Possibly!! I will check tonight. If that is the case how do I rectify it?
What part has melted?
The bulbholder on the end of the wire?
Or the actual light cluster on the front?
Which ever it is you need to place it.
