lights not working at back
  Clio 1.2 16V
my rear lights are not working and my sidelights at the front along with the lights on my dash and stereo anyone help?
might need to take it to an autoelectrician unless it's a common problem and someone can advise. they'll all be on the same circuit, so may be it's a problem with the fuse box - could try checking the terminals (etc) in the box
edit. or may be the column switch. it'll be something in the circuit in between the switch and the bulbs - need a wiring diagram, really. bad earth?
probably enough to be going on!
check the relays under the passenger footweel i'd bet the one for those itesm you have listed has come loose just push it back in.
Its easy enough to get to it right down under the dash by where a pssengers feet would be. Easy enough to knock
  54 1.2 dynamique
thanks alot mate did the trick! genius
  172 Race Car
ive seen that a few times, passengers with big feet!!
