Little water leak...
Car  RenaultSport clio 172 mk2
The radiator water that you put in the little plasic bottle underneeth the windscreen seems to be leaking. I fill it up and its gone within a day or two and you can see it dripping out the bottom of the car slowly, especially when its running.
Anyone had this problem? Could it be a loose clip or something?
Would you suggest putting in some kind of Bar's leak product in to block up the hole as a quick fix or has anyone got any better ideas?
You need to find the leak, it could be anywhere in the cooling system, or are you saying the bottle itself is leaking??
you need to find the leak fill the coolant bottle up put the cap back on and leave the car running and have a quick look and you may see it
