Locked my keys in my car. HELP ASAP
Car  Renault clio 1.2
so ive managed to lock myself out of the car with the keys still in the ignition. very stupid i know but need to know a sensible way of getting into it causing the least amount of damage possible.
Pull the top of the door back carefully, poke unlock button or pull inner-release handle with coat hanger.
Call the AA or a locksmith.
Failing that, pop a window as far away from the drivers seat as poss !! Glass is awful and you will find it everywhere, for ever and ever...
DONT BREAK THE GLASS!!!
if you peel the seal off around the bottom of the drivers window and let it hang you can knock the clip off that holds your window on the regulator.
then take your window off the regulator, slide it down carefully and get your keys or open the door. re-assemble and done with no damage what so-ever!
Managed to prise the door open at the top enough to push a thin piece of wood down onto the window switch as the ignition was on. Thanks for the help though.
