Expect wear to the steering wheel, silver electric switches, and drivers bolster
Make sure its had its cambelt done, before 5 years and 50k, or the engine will prob be fooked
check the gear box, if its not tight, and is very slack it will be ragged and therefore prob mechanically s**t
Make sure its been serviced regularly
check the ligths etc are all ok.
If it sounds tapity, or isnt as pokey as you'd like, its prob that the previous owner has used 95 ron petrol and shite oil, i changed both of these on mine and now its as sweet as a nut
check for a wobble in the steering wheel, dont dismiss it immediatly if there is one , as it could be balancing, tracking etc. but if there is one i'd get an independent inspection if you havent got a waranty on it as it could be steering related
Other than that the ph1's are bomb proof so everything should be ok. Also on the flame reds expect pitting to the alloys, as every colour except silver was imported and therefore the alloys are unlaquered.
