Looking to cam my ph1 172 help needed please!!!
Car  16v
Right I am looking for some cams for my car, not too bothered about how it will idle just want cams that will make a lot of difference on bhp and torque.
I would like to hear from you guys who have had your 172/182 cammed and what gain you got. Also costs involved.
Speak to Andy @ GDI, he did cams, inlet match and remap on mine before I owned it and it made 196bhp and around 175lbs/ft of torque. Well worth it imo.
thing to remember is with some of the profiles being used what you gain 5k + you loose at low revs,i'll probably be told i'm wrong but i went out in a 172 with liary cams and it was lifeless below 5k
really depends on the profile thats used. the other consideration is that you will probably want to go with a more sophisticated remap. so say something like the omex 600, and thats not a cheap mod to do.
it's not that expensive and it's an easy 25-30bhp+ depending on engine. contact Andy and find out, he'll have package deals and his results are actually proven unlike a lot of other tuning companies who claim massive power and never actually get anywhere near it.
omex 600 would be about £1,000 fitted which i wouldnt call 'cheap' myself. in fact id actually call it a 'significant amount.' you can then spend £650 on the cams, and about £500 fitting them. so its starting to add up. unless you went for a milder cam, and then a basic remap but then your limiting the results you can achieve.
if i had the money i almost certainly would go for it, but cant justify it at the mo.
Omex 600 is only about £500-600 and you'd probably not end up paying for mapping and RR time as part of an inlet, cams and ECU package deal... yeah, they aint cheap and might be over kill for just cams, but they are a great ECU... especially when OMEX upgrade the Eprom for you :D
no need for OMEX on just a cam setup (unless its a bonkers cam)
Schricks are awesome, all the cars we've done are pretty ballsy!
didnt chris get the cams from ben r though?
i think the omex is £600 on its own?then theres loom and sensors
£600 is the cost of the hardware. You need a new loom and time to wire that loom in. You also need ALOT more time then just a few hours on the rollers as you have no base settings for your map.
The mapping will be included in the price of the package which is why you arent getting it for free. Tuners arent charitys and they definately arent cheap.
What was the OMEX eprom upgrade for?
As for the question on cams speak to BenR he wont feed you with bullshit and will give you an informed opinion on the best cams for your needs.
In fact speak to all the tuners and see who you "believe" knows what they are talking about.
I have also been told Nick at Hillpower knows his stuff but have no personal experience of him.
As said, no need for standalone......it certainly isnt more 'sophisticated'. You have one load rpm map, where stock ECU's can have several maps.
And as for this Eprom upgrade......why has it taken years for Omex to realise that its needed.
So any one getting high torque cams from Angelworks would be quids in cos they would'nt need expensive electronics to run them?
As for the question on cams speak to BenR he wont feed you with bulls**t and will give you an informed opinion on the best cams for your needs.
yeah nick does know his stuff his downfall probably is that he's too honest and some people hate to hear the truth
Swapping to a standalone ECU is a last resort, quite alot can be done with the stock ECU.
There comes a point though that too wild a cam will confuse the MAP sensor readings and cause the ECU to play hanky panky with the FBW throttle.
no idea, but it makes no difference though, all they are is cat cams.
ECU was upgraded because of an idling/running issue in certain weather conditions and temps... no idea why it's not been known about before, don't have a clue how long these things have been out, but it's been upgraded and it's running amazingly smooth now.
googled Omex 600's and 1st page that comes up is Yozzasport, over £600 for the ECU, 2nd place comes up £545, I reckon you can easily get one for £500 new if you look about, cheaper off Ebay.
For cams I'd just go see someone that can map the stock ECU though as has been said, Chip Wizards is probably the best I've seen from an RR and 1/4 mile results perspective.
Nick told me that head work on the Clio was not really cost effective.
His honesty makes him a busy man as he is booked months in advance.
heard that from a few 'experts', however if you look at the job Ste at Port Formance did on Gaz' Nana Hybrid it made an extra 10+bhp iirc from the before and after and it's a f**king animal now, will easily keep up with mine!
:eek:
was going to say, ja.jack is talking about the F4 as it is CNC finsihed, the F7 is plain cast and not as good in stock trim.
However, if that were the case then i wouldnt see these sort of flow gains with JUST a valve seat job and shortside blend.
Inlet
Blue is stock head with just CNC valve job, and the green is the older traditional spec stock valve ported head. As you can see, upto lifts of 0.35" or 8.9mm the VJ only outperforms the ported head....and since the stock engine only lifts up to 9,9mm your pretty much quids in for cheap flow gains since there is no extensive porting to do, thus no labour.
Ex
Blue is CNC valve job on ex, green is stock ex, but the gains are even better.
This is without even any porting bar a short side blend into the new VJ which is what i've been spending alot of time developing.
So IMO, its worth doing the new valve seat design rather than full headwork on midly tuned motors. New peak flow fully modified figures are now substantially higher than previous work.
its still nearly a grand once youve brought sensors and loom
yeah, but I did say it's probably overkill for just cams, but it's deffo worth doing if your going to go further than that... plus I'd buy one off ebay, go for much less on there with loom etc. Cheaper than a basic DTA anyway, I was quoted £1500 for one of those including setting up and mapping with all sensors and wiring done
i'm not on about needing it for cams i'm just saying its still 1k with loom etc,dta is about 1k also with loom and sensors but is a better kit
