Loosing coolant - fast!
Hi
I'm loosing coolant fast.
It leaks a whole header tank in about 20 miles!
I think I've found the leak, it looks like it's coming from the water pump. My friend says it's a seal on the waterpump and you can see dried/burnt coolant on the gearbox.
Am I going to need a new pump?
I know I will need a new cambelt if I need a new pump - anybody know how much this is roughly to fix?
Matt
what car do you have? if its a 172/182 you will only need a new aux belt not a cam belt id probably get a new pump
waterpump is on the other side of the engine to where the gearbox is.. drivers side >waterpump/stroke rad or bottom hose...
passenger side >thermostat housing,top hose and others around it or stuffed rad
172/182 or 1.2 etc?????
Sorry, my mistake I did actually mean the thermostat housing. That's where it's leaking from.
So the thermostat housing is not on the cambelt?
It's a Clio MK2 PH2 1.2 16v
It's a common place for them to leak as the plastic fails allowing the seal to pop out... It's a pretty high pressure area to.
New stat and all will be well... Buy a genuine Renault item though as the cheap ones don't last.
Mick
