hi guys any idea why the car would lose power randomly , wont go over 60 mph . like its got a limiter. turn ignition off and back on then its fine . any help would b great
Sounds to me as the car has gone into "limp mode" is there a box with a wonky line going through it on the dash ?
I believe that it means there's a electrical fault somewhere I.e a sensor or something.
hi guys any idea why the car would lose power randomly, wont go over 60 mph . like its got a limiter. turn ignition off and back on then its fine . any help would b great
Failure upon that I have known the crank sensor to cause this problem just as much as the accelerator sensor....
I'm guessing you don't have a diagnostics tool ? Obviously then you would be able to identify it without the gamble of buying another part that doesn't need to be replaced. Unless you know someone that can get it diagnosed for you ?
