Lots of fault codes and refusing to run meglio!!!
Car  Clio 197 !
Hello & thanks for having a look .
For no reason at all the car drove perfectly I did my shopping got back in and it wouldn't fire, the engine was turning over but no life ! The aa recommended that the crank sensor needs replacing but didn't read the codes . Luckily a mate has a code reader see attached . We got the car to run as it should but didn't change anything sensors or otherwise ??? We removed various bits an bobs and checked theres a good spark etc .
I have on a couple of occasions had the dreaded check injection and it starts on 3 cylinders , after wiggling wires it has always been cured once restartes, I have plans to get the updated injectors and a remap bit is this likely related to my current issue and these codes ???
Also these are the codes that stayed after we reset and had the engine running .
530 is a fault with the Aircon which has been removed so no issue there .
