Loud noise on over run
mad in general
  Clio 172 phase 2
Got this strange rotational noise when running down the revs in gear.
Really loud and is almost like a whump whump whump sound. I know that sounds daft but will try get a recording.
Anyway. This noise disappears completely the moment the clutch is pressed in.
I can faintly hear it when on light throttle but it is not obvious when on power.
Any ideas?
mad in general
  Clio 172 phase 2
The full clutch kit was done along with a gearbox refurb only 15-20k ago. Hopefully neither of those!
No remap, standard engine wise.
It does seem like it's got to be a box fault though as it's only when in gear. Knock it out or clutch in and it disappears instantly.
mad in general
  Clio 172 phase 2
It would appear this drive shaft bearing is ruined. This'll be the source then.
Is it replaceable or a new shaft?
Speedo Gonzales
The bearing is the centre support on the shaft, without it it would just flop around surely
PH2 Shaft below with bearing
172 CUP/PH1 shaft below which doesnt need the bearing
I'm intrigued to know how the f**k your shaft didnt put a hole in the block without the bearing 😂
