PH1 V6
As some of you may know i have had problems trying to find this blasted knocking from the O/S front. BUT...... i think iv found the problem!
Im pretty sure my drivers side lower balljoint has seen better days but would just like confirmation of "worn" balljoint signs. The passenger side lower arm was replaced 6 months ago but from looking at receipts and history it appears the drivers side has never been done.
When looking under the car and looking at the lower arm on each side, where the arm connects to the rest of the hub assembley (where the ball joint is) there is a gap which opens up and wobbles when someone turns the steerings wheel (dry steer). The passenger side sits flush and only moves as it should, or in other words there is NO gap or loose movement.
Therefore i am assuming there is play in the balljoint and it will need replacing. good idea to do the lower arm at the same time as it will come with new bushes
and considering my car is over 9 years older would be nice to freshen it up.
Could anyone confirm if the above sounds rite?
