coolspot007007
Seat Leon Cupra
I can't seem to find any posts about changing the lower gearbox mount but mine seems like it needs replacing. It looks like you need a lot of clearance to get it out though as the threads are quite long on the top and bottom. Is it a case of unbolting all the other mounts and jacking the engine up or will anything else need disconnecting? Or will it need the subframe dropping to give enough clearance as it looks like you'd need a good 3" to get the new one in?
