Lowered on H+R problems with rubbing
Car  R35 GTR
I have 60mm at front and 30mm of thread left at back to go down more with, but I am getting wearing around the outside of the rear tyres. Should i be worried with the PE2s?
Or should i lift it up a bit more.
Also measured ride height on flat surface and theere is about 3mm difference between left and right , front and back, would this be a good tolerance or should i get it closer?
thats your problem, on phase 2 172's you shouldnt run any wider than 195 if lowering more than 40 mm ish
it will be the metal tabs that stick out on the arch linners. cut or grind them off, the arch linners won't fall off. i had to do it to mine & voila no rubbing.
matt.
gt_gaz said:
also whats rubbing...? and where?
on the ouside wall, outside radius, i think matt^^^^ may have a solution there though, will check tomorrow.
I am confooosed now.
he's on about the front bumper brackets, you said rear?
i think?!
i'm on about both, i had mine ground down on the front & back but like yours dave mine was worse at the rear. i think it was both bumper bracket & arch linner tabs.
will have a look tomorrow and try and get pics.
