The fronts, whip the shocks out - undo the top mount and the two bolts fixing it to the hub. Acquire some spring compressors, compress the spring on the shock to the point where it will not ping off and impale you when you take off the top mount, plate and bearing thats on the top.
Take off the spring undo the spring compressors, compress the new springs and out it all; back together!
Yep! On yours as its got drums on the back, you have to push them up individually, i.e with a jack, then tap the torsion bar back in and they will lock in place!
