LSD on Mk1 V6
Car  V6 Mk1/Beat/E320/Mcoupe
Hi all,
I remember reading somewhere that the Mk1 V6 doesnt have LSD. But I found out that my Mk1 V6 does have LSD.
if the car is in the air and both the wheels move, then it has lsd right?
That would mean its rear wheel drive.
An LSD comes in handy when the traction to the rear is compromised. LSD transfers power between the two rear wheels, a normal diff doesnt. So one wheel is going like buggery and the other one doesnt move.
And if thats not true, it does half sound like I know what Im talking about doesnt it.
Andy D said:
Errr ... yes ... it's a V6 :hail:
yes i know that, i was referring to "if both wheels are off the ground and both move its got an LSD".
That fact just makes it RWD, which it is.
Damn you to Hades! ;)
In a normal gearboxed car if you jack it up and spin one wheel the other will spin in the oposite way thats just normal not sure what happens with an LSD though.
with both wheels off the ground ..if you rotate a wheel and the other one rotates the opposite way no lsd...if it rotates the same way it HAS a lsd.
ok?
ok?
Then mine def has an LSD. Very wierd...... But good surprise
is it possible that the ones in Hong Kong came with it? This is really wierd. Maybe previous owner fitted one.
172's do the same, and they haven't got an LSD
you can test if you have kilo, when stationary turn the car to full lock, floor the throttle and dump the clutch
let me know what happens (if you f**k your clutch, its not my fault!!! LOL!!)
we never sold any with an lsd and never heard of an owner putting one in.
nor have i heard of one for that box anyway.
then its pretty wierd. dont know why mine seems to have an LSD then. but im pretty sure mine has lsd. with the car jacked up, both wheels went the same way. I will check again this weekend.
Why would I hear clunking. I can check again this weekend, how can I confirm?
So if I have the car in the air, let go the clutch in 1st both wheel spin the same way=LSD?
^^ Nope, that would happen normally.
Try doing doughnuts in a big empty space. If you can keep the front wheels on the same spot with the back doing wild circles, you have an LSD. If, however, your car just goes flying off the spot, you don't have one. :)
Just thought, another way of telling is to do dump the clutch from a standing start...if you produce a number 11 on the (dry) road, you probably have an LSD!
Cant try that, I have R tires on my car, will probably bust the tranny or the drive shafts.
with the rear of the car in the air, spin one wheel by hand, the wheel on the other side will spin the other way
you haven't got an LSD 100% promise
A few things to check to see if you have an LSD...
As you have said, jack the car up, if both wheels spin in the same direction in neutral you have an LSD
Also if one of the drive wheels is on the ground when jacked up, the other will not spin, even in neutral
LSD's are clonky and will notice this most when in neutral at idle. Also tend to make a slight grating noise when on the move
Hope this helps
Col
