So that old chestnut of crank pulleys. I've seen threads where people are changing to Mégane pulleys as they want the crank pulley locking. However many these are old and thanks to Imageshack fuckery, the images have disappeared. Googling for more pictures doesn't show anything clear either.
So what is the difference between a stock 1*2 crank pulley and Mégane/Clio3? Does it affect timing up the engine and does it lock the cambelt sprocket on the crank too?
I'm not actually bothered about the locking nature of the Mégane pulley, more that those can be had for under £50 new. Where as the Clio 1*2 pulley I'm struggling to find an alternative source to and Renault was £162 for.
Essentially is the Mégane/Clio3 pulley effectively a straight swap or is they more messing around if you go that route?
Renault OEM part numbers for reference:
Clio 172/182: 8200386460
Mégane/Clio3: 8200619927
