Manifold and cat springs.
Car  Clio sport 182
Has any one come across an easier and better way to keep manifold and cat connection tight without using those shitty springs?? Such as just a simple nut and bolt? And if any body has done this has it been ok, or is it better to just make do with the springs?
Are you using a genuine renault fitting kit??
Most of the other cheaper makes are about as much use as a chocolate kettle
Haha ive heard those kettles are good!!
It looks like its a genuine set thats on, it turns out the end has corroded on the bolt and the hole on the manifold so it pulled through,
So for now ive just put a washer on it and its holding pretty snug, what a shite idea though!!
