Megane not starting sometimes :(
Car  Black PH2 172 FF
The Mrs has a 96 Megane.
Just recently it has developed a starting problem which happens just now and again. When you turn the key - there is nothing at all, no noise or anything. Not a fault with the battery as someone put a booster pack on it and it still didn't start. After leaving it a couple of hours, it started, but only just. Then after driving it for a bit, it would start again like normal.
Could this just be plugs/leads?
Any help would be good - thanks!
Doesn't the starter motor make a horrible noise when it's on the way out?
This makes no noise...
When it won't start, the radio and all other stuff DOES comes on....
Ok then I'c check the cars getting a spark so unplug the coils and check then then check the cars getting fuel but if you cannot hear a starter kicking in then thats most likly the issue so check its relays
