Removing old splitter,
1.jack the car up and whichever you have choosin to jack up turn the wheels to the other sid of the car.
2.underneath where the splitter is mounted you will see two staples(per side) 3.prize the splitter away from the bumper with a screwdriver
4.then when theres enough of a gap between the splitter and the bumper 5.get a stanley knife and slice the splitter where the staple is (just the leght of the staple though so it doesnt damage your splitter!)
6.it will then come away, from there on it is held in by little triangles moulded into the bumper it just pulls out of theese with a bit of force!!
7.than repeat for the opposite side!!
New splitter fitting,
Position the splitter in the centre and clip in under the triangles at one side only and when the centre of the splitter is in the centre of the bumper go to the side and cut away how much needs to be cut to be flush with the bumper(cut same amount off other side)
cut a few slots along the splitter but dont go over the line! you will know what i mean when you see the splitter.
then get around 10 self tapping screws. drill a small pilot hold through the litle triangle and the splitter when its in place then screw them in.
JOB DONE!
Any questions or anything you dont understand please ask!!!
1.
JOB DONE!
1.
