mesh
  megane
rite im meshin me front bumper tomoz just wonderin if any 1 had any problems etc wen doing it if so wat>??
its a dynamiqe billabong haha(mk2 facelift)
andy
  Renaultsport Clio 182
I have meshed mine
BUT its hard!!!!!!!!!!!!!!!!!!1
I ended up with cuts and grazes all over hands & arms!!!!
Are you taking to bumper off?? (recommed it)
What you email i will send you some as the uploader is not working
f**ked it up though!! big hole in mesh!!!!
I am going to do mine again when a have some time!!! this time i will be taking the bumper off and doing it properly!
heres mine...
http://erc.qmuc.ac.uk/cliosport/file.php?image=1057321131__black_lexus_lightshhh_1.jpg
took a while - like a day...worth it mind you.
make sure you buy a glue gun with lots of glue!!!!! and some super super super super strong epoxy glue stuff. do not attempt to bend the mesh around the contours of the bumper whatever you do - it will not work!
take off the bumper, where the two bits are where i have meshed, cut off all the plastic bits that will get in the way of the mesh. cut the mesh to size (cutting bits off the ends and sides so it fits tightly) and place it flat on the area. now on every bit of plastic touching the mesh, use the epoxy glue - put weights on until it dries (about half hour). once the mesh is fairly firm with epoxy glue use sh*t loads of glue from the glue gun. it can run down the sides as much as you like, just not the visible sides! all in all, make sure there is sh*t loads of glue to make sure the mesh is a firmly in place as possible otherwise all you work to get it to fit will be wasted!
hope this helps
charlie
  megane
alrite ppl thanx 4 yer help i did me meshin yestewrday best to get sum1 esle to help i havent got pics yet but will have soon so il post them up
i had no probs with mine though even did the bottom splitter holes
cheers again
andy
