K
kiwiclio
Hi from New Zealand - the situation: broke #4 exhaust valve, took out the piston and so heavily scored the block that it's new engine time. Have sourced another Ph1 172 engine with eqiv. of 40k miles on it here in New Zealand. The car: Ph1 172 dedicated to tarmac rallies (150 miles a day of hard-out on special stages with 2 or 3 times that at normal road speeds touring between stages). Work on the old engine had been mostly on intake & 'externals' - ITBs with Link G4 engine management and stuff like A/C delete, uprated coil packs, leads, water hoses, catch tank etc. Had reprofiled cams to emulate CatCam 421s. Was running ~180HP at the wheels.
With 'new engine' options range from dropping in exactly as is (freshening waterpump, cambelt etc of course), putting ITBs on etc - to an all-out build. What I want to do is strengthen the engine without spending a fortune - i.e. don't want another broken valve, etc...immediate thoughts were to out in uprated valves and springs alongside a genuine CatCam, but not the forged piston/rods route given cost and goal is not power per se...
Anyway - would appreciate all thoughts as well as anywhere for parts in addition to K-Tec.
With thanks,
Martin
With thanks,
Martin
