Mintex brake disks???
  Corsa now :0
Recently my brakes started scraping due to the pads being worn so i decided to get a set of Mintex disks and pads. The new disks that came are solid disks but the standard brake disks are vented. Do you think this will really matter?
cheers
  Clio Mk2 Ph3
cheers
Solid disc:banghead::banghead::banghead:?????????You have ventilated disc ,259mm with ABS.Without ABS,238mmsolid!!!!!!!!
for non sport you can get eicher ones really cheap off eurocarparts
just make sure you get ABS ones that are 259mm diameter
