Miss Fire - Crank sensor?
  172 FF and Fabia VRS
Hi All
over winter not used my Clio at all, used it this month and started, but developed an on-off miss fire
got worse now and it there all along
Swapped the plugs as when I had an issue before its happened then. Same no difference
Got a new coil pack arrived I am going to test, if it still continues I think its the crank sensor
where is best to get one from? quoted £50 plus £25 for the loom for gen parts. where else does them?
not sure if I should trust the ebay stuff - unless anyone can advise
thanks
Phil
just found a thread about a chap called dan who cleans them - sent him a message - waiting on a reply
says he is midlands too which is cool
Just a thought
If the miss fire happened at full revs/under load
What’s that point to?
Was an injector
Moved it to another cylinder and the issue moved there when in plugging them
Thanks for your helps
