missfirey problems would cylinderhead cause this?K4M
CLIO-Si
Car  1.6Si + 182
hi everybody,
as above iv got a missfire under revs and low idle which drops on clio's own accord, Car is a - 99 v reg 1.6 16v Si k4m 102k
car has been off road for a long time(prob over a year) in this year ive needed new radiator and manifold, clio has been overheated a few times and manifold sounding like a rally car as one of the 4 branches was burnt right threw.
iv replaced rad+mani and since then i have had a lumpy idle and missfire threw rev range,
ive drained and flushed coolant and oil yesterday(sunday 24th) to which its slightly helped thou still got the dut-dut-drrr-dut-dut-drrr-dut-dut on idle then once revs are on off course the drrr becomes more constant.
im thinking since its been overheated a few times maybe the head has been caused sum damage....
ive replaced my battery and was given a 063 not the 065 so unsure whether this would cause anything...
i took my compression tester yesterday to test cylinders thou i couldnt get a hold of the spark plug with the long sockets i had and then just got on with oil+coolant change...
kinda stuck now between sending it to garage for head treatments or investigating plugs+leads further myself.....ANY CLIOSPORT HELP WOULD BE GREAT!!
MANY THANKS :)
Compression test is a good place to start, if the gasket is yielding between a couple of cylinders it could cause the sort of issues you are talking about.
yeah i need to find the right socket to get to the spark plug tried everything i had yesterday and couldn't get it with it needing a long socket
swapped coils to ones i had changed last year as i bought a new set to see if they improved..
one spark plug was fried the rest ok so after checking all plugs and compression im started and no missfire..so all good untill i try start it from cold and it struggles again....
.... not starting and im swapping coils and plugs to try anything an nothing...so i try start it in first to move car a little bit an next turn of the key it starts...so away fior drives and all seems ok and good threw the gears...
left while had tea and a cuppy and not starting again so i dunno...
