so opposite side to the washer bottle and pump?under scuttle panel on the left mine has a major humidity problem blowers make the windows steam up. pollen filters been changed.
I'm going on the assumption they're in the same place...ive got a 182?
I have this problem too. Passenger carpet gets wet sometimes and the rear bench.Same boat here, but I get a small puddle under the rear bench. But there's no trace of where the source is !
@AlexW get in here and clear this up for everyone! :smile:
cool, it is pretty easy to get to, or a paion in the arse??It's under the drivers side scuttle panel so you don't need to remove the wipers first :wink:
http://www.cliosport.net/threads/guide-to-changing-pollen-filter.223024/cool, it is pretty easy to get to, or a paion in the arse??
anyone got a link to where to buy a new filter online?
In the wife's dynamique the sunroof was letting in a load of water. That's sealed up now and dry as a bone.I have this problem too. Passenger carpet gets wet sometimes and the rear bench.
Thanks very much!In the wife's dynamique the sunroof was letting in a load of water. That's sealed up now and dry as a bone.
The cup doesn't have said sunroof, so the only things I can think to look at after the pollen filter are:
Any more from anyone?
- Door seal
- Boot seal
- Rear light seal
- Aerial seal
It's under the scuttle and you don't need to remove the wipers to change it.
Also make sure your recirculation flap isn't stuck. You need fresh air coming in otherwise you'll steam up.
Hmmm I'm not overly sure, I think @McGherkin had an issue with his so he might be able to shed some light on itwhere is this said flappy flap?
Sorry, your tag didn't work.Hmmm I'm not overly sure, I think @McGherkin had an issue with his so he might be able to shed some light on it
MK3 scuttle panel has a known problem, take off the panel and there are a few rubber drains (3 IIRC). Pull them out towards you, theres a stupid flap on the end for no reason that stops water flowing out, I think its to filter leaves or something but its on the furthest end of the hose?! Cut the flaps off, problem solved and no more scuttle panel flooding. Did this on mine and it was fine for a long time after right up until I sold it, probably still fine now.My Mk3 does it as well.
Not even my old P reg Vectra had this much of a problem! It's also shocking how much water collects in the scuttle panel as the drainage is so bad.
Can't find any moisture getting in the car. It mostly seems to be when it's either very cold, or after we've got in the car and we bring in the moisture (wet shoes leading to wet mats, or we're soaked from rain).
