Mk 2 Clio brake pad pattern...???
  Monaro VXR/Cupra TDi
Is this the correct pattern for a front brake pad to fit a Clio 182 Cup caliper?
Apparently it's known as a BF 4 ???
Any ideas Edde?
They do, but I need to 100 %. If not, obviously the pads I'm ordering won't fit.
Any ideas Fred?
  Lots of Alfas
They look about right, what make are they?? The correct measurements are about right. SHould be:
Criteria:
Fitting Position
Front Axle
Brake System
Lucas
Width [mm]
128,9
Height [mm]
55,4
Thickness [mm]
18,3
Thanks gents.:)
I plan to fit a pad that I believe no one else has tried on here. It's a high performance item with a working temp of 0-850 c !.
Not a high metallic compund like PF 97's or Blue's. Friction may not be quite as high but, wheels will not be damaged by sparks as they are from high metallic pads.
