As some of you may have seen I am having a right ballache with the valver. Basically the car will not start and the reason for it is that the injectors are not firing. I have checked the voltage at the injectors and they are only getting about 0.1v to the injectors. I have checked as many sensors as I can and they all seem to be OK. This left me thinking that the ECU was at fault but having changed that it is still doing the same thing. The car continues to spark as normal, but does not have any fuel as the injectors do not fire.
So far I have changed the ignition module and the ECU without any change. Has anyone else had a similar thing happen, and if so what was the cause?
What suggestions has anyone got for what I can try/check? I really am in need of some help as I'm getting nowhere with it and have hit a bit of a dead end.
Thanks.
Thanks.
