mk1 clio electric windows....
Well im not sure if its a common problem with the mk1 clio electric windows BUT on both clios i have owned the windows have gone up slow, they come down fast but then creep back up, is there any way to cure it, i was going to grease the window motor but thought i would ask on here first b4 i wasted my time.....Thanks
Mine used to do the same, greased the window slides either side, worked it a few times and it sorted it
mine are a little slower to go up. what i like about them is how they slow down if u close or open both at the same time. good old french engineering
as tom said just lube the runners up both sides make sure u do the part inside of the door panel to, that will sort it out.
