Hi guys,
The sunroof on my soon-to-be mk1 ph1 1.8 16v would not close on the testing. The owner has since closed it manually, but I wish to fix it so I can use it.
The sunroof motor is still runs perfectly on it, but apparently it seems to be some gears/cogs have worn out.
Are replacement parts available or expensive? (i'm used to air-con now and will miss a sunroof with air con )
Matthew
Matthew
