Mk1 - F4R, Fuel pressure regulator??
Going to be deoing this conversion soon, ive noticed on the ph1 172 fuel rail there is no pressure regulator and just one fuel line going to it, where as on my mk1 there is 2 lines and a pressure regulator, how do i over come this when doing the conversion?
ph1 172 have two lines and fuel pressure reg ph2's that have it built into the tank
The ph1 outside my house has 1 hose in! It is the twin lambda loom to.
Does this mean i will need an earlier loom aswell?
you have a very late ph1 then. seen a few like that, but the majority are 2 fuel lines. could convert the mk1 to single fuel line (beanie has done it) if you can be bothered. standalone FTW
phase 1 bits ftw, i have a spare fuel rail with injectors, phase 1 so 2 connections for the lines ;-)
i would have thought you would be able to. i thought the second lambda is just for the dash warning but i honestly dont know
The loom ive got on at the moment is a twin lambda loom. The loom I originally used was a twin too with the wiring chopped off, so id guess my ECU is a twin lambda one too. All runs fine.
it is just for a warning light. wont effect running at all. most important bit is having an ecu for the same fuel line setup that you have really
