mk1 rsi problem can anyone help ?
my mk1 clio rsi has an idle problem , it sits between 300 and 900 revs constantly reving between , it doesn't just tick over nicely ?
why ????
ive taken it to loads of garages and got loads of different toughts on the problem !
is it ecu , injectors or sensors domewhere ?
please help i'm desperate !
cheers all
was gonna say check things like plugs, leads, dizzy and rota arm and att the conections around the tb
cheers for the reply's guys,
done ht leads , plugs , air filter, oil change , fuel filter and fuel treatment
with no fix
will take a look at the items listed to clean/check
thanx alot for your help !
any more idea's if that doesn't work ?
i was thinking maybe the scrap yard !
cheers
tony
Throttle body distorted causing an air leak round the butterfly spindle.
Check theres no vaccuum leak from MAP sensor or cracks in the inlet manifold.
