mk1 strutbrace problems
  mk1 clio 2.0 16v
just got a sparco strutbrace but has no instructions to fit by the looks of it do i have to drill into the top of the strut to fit is is hard to do?
  Fiesta ST Stage 3
is there any bolts on the struts ? On some cars its just a case of take off the bolts wack on the strut brace then wack back on the bolts .
Yep your right drill holes in the strut tops then you should use some proper bolts to hold it in place plus make sure you piant the hole sto stop rust starting.
Not had to do realy but IMo the only proper strut brack is properly bolted to thge subframe 99% of the stuff out there a waste.
  Caddy Maxi
make sure you turn the coil pack upside down too or it will foul the strut brace path ;) simply unbolt it and turn it 180 degrees :)
