I've got a MK1 Williams and noticed that i've been overheating recently quite quickly when sitting in traffic. After a bit of investigating I've found out that the fan will only cut in if the engine is not running. As soon as you cut the engine, the fan cuts in.
This can't be anything to do with thermostat or the temp sender unit, but must be some kind of other electrical fault.
Has anybody else come across the same problem?
