Mk2 Clio .. headlights.. do they come apart?
Hi all
my mk2 clio failed its mot on headlight pattern. Just fitted brand new bulbs from halfords and no change.. failed again :dapprove:
ive just removed the headlights from the car
can the front clear plastic/glass be removed from the main unit so i can clean inside?
thks
Dave :)
You can get them apart yes, but I don't think that's how you go about altering the beam.
Beam pattern? Surely your bulb/s must be fitted upside down?
You can't 'alter the beam pattern' as that is imprinted on the case lens.
Are they visibly dirty?
Have you tried the adjusters?
How was the beam wrong, as in too low/high or was it scattered?
just tried adjusting, all it does is raise / lower beam
the problem is the beam when projected at the mot station / or a wall.. is not straight.
it flares up at the ends
i think the headlamp lenses (plastic) are just aged, heat degraded and warping the beam
no alternative..
new headlights me thinks
thanks all though
The beam is meant to give that pattern though I'm pretty sure.
Something like this ___/ ___/ is normal.
It would be the other way though, no? Raised at the nearside to light the pavement/side of the road?
correct
da's post is a left hand drive beam patten.
sounds more like the bulb in the wrong way, nowt to do with the actual lamps
Theres no way of being sure by adjusting them yourself, take it to a garage that does MOT's they will have the equipment to get them set right, if they tell you they can't set them then think about new headlights.
correct
Deffo not bulb the wrong way gents.. its a one way only fit
will grab some new ones tomorrow, i think theyre only £45 each....
