I found the one for double optic conversion but not fogs .. my lights and wiring haven't arrived yet but they are from a 172. Hoping once they get here I'll just work it out from the connectors attached but it probably won't be that straight forward lol
There's a loom which connects the two fog lamps together, and to the connector, which if installed (my 1.2 never had it) is in behind the headlight on the passenger side IIRC. Someone with a 172/non sport with fogs will have to confirm.
Two screws is all that holds in each fog light, should be pretty self explanatory. Fog light blanks should just pop off.
When you say you have the stalk already, does it have two fog light positions (as well as off) or just one?
Yeah, I only had them because I changed the bumper, and the new one happened to have fogs on it. Looked into wiring them up but didn't have the loom connections.
Of course you could go completely aftermarket and create everything from scratch with your own switch.
I might consider it tbh, would really love a working pair .. even if I don't use them often. I'm also toying with the dual optic set up as I really hate night time driving with the factory lights.
Heard nightbreakers are a cheap solution in the meantime though?
Here's my 'Adam' .. currently has no mods at all .. he's been offroad for a while and I'm treating him to some upgrades!
Dual optics is usually much easier, but check inside your fusebox for the space for the dual optic fuse, as some cars don't have the same fusebox. Mine did though, and was a grande.
Quick update .. my ph2 lights arrived yesterday and got those in and working in less than 20mins thanks to the member guides! I plan on doing a bit of rewiring to get both rear fogs working though .. never understood why ph1's only have the driver side rear fog when the wiring is there for both!? I've also discovered I've got a dodgy hazard switch too .. have to give it a good knock to work lol. It also makes my passenger side brake light flicker. Pulling it out to check connections later .. still waiting for fogs though
Fogs arrived this morning! Whacked them straight in .. love how they look, shame they're not wired in yet though.
@McDriftin .. I'm gonna have to go aftermarket with them. Any tips on what to use? Want to put the switch in by the headlight adjuster on the dash.
Am I also right in thinking I don't have connections for dual optics either ..
I'll also need to remove the fogs before MOT right? Since they're not wired and working?
