Focus TDCi
I converted my headlights from the standard ph1 lights to the Dual Optics a few months ago. I only changed the wiring, no fuses where added etc. and everything has worked fine ever since.
I'm no good with technical terms, however, this week the second setting (i.e. the one you use in the dark) doesn't change anything from the first setting. So, my only options are sidelights (first setting) or full beam. The fog lights still work.
I've checked the wiring and it seems ok and also used a fuse tester / voltage reader thing to check every fuse inside the car. It didn't light up for any of them so I assume that means they're all ok? I know there are a few more fuses near the battery under the bonnet, but I don't know what they're for or how to check them as I can't see the wire inside or see anywhere to use the tester.
Due to the specific nature of the fault I was sure it must be a fuse or something.
Can anyone help me please. Is it likely to be a fuse? Or a blown bulb? Or...
Thanks for any help
Ian
Thanks for any help
Ian
