Hi guys,
Sorry if this is a stupid question. But do standard Mk2's have rear speakers? No sound is coming from the back of the car, so is this because their arnt any, or do i have to change something on the cd player?
I had a feel around under the cover, there is something running along the bottom , but not sure if its wires. Would the wires be loose and basically in position?
They should be in loose if there in there. Probably not then. For the benefit rear speakers would give you (very little) its not worth bothering with the wiring to run them off the standard headunit.
If they were amped then it would be easy enough to add them.
10cm speakers... Il use this thread rather than start a new one.
I have thought about the same thing recently after valeting the car and finding these pods.. I was able to pop them off and gain access to what feels like the wheel arch with the soundproofing? But I Can't find any wires anywhere.. SO!
I plan on having some ambient noise from the rear because atm it just sounds plain coming from the fronts.
I was hoping to run them from here but .. I do have two subs and an amp for the rear.. Would it be better running them from the HU itself .. or using the amp to power them? (the latter seems the easiest option IMO)
Thought id get some advice on this before i jump into it!
