Mocal Oil Coolers
Car  ph1-mk1-1.4, white
Hello we need 6people for this.
Should get some good rates on oil coolers.
We can get 235mm WIDTH:
13 row, 1/2" BSP
13 row, 5/8" BSP
16 row, 1/2" BSP
16 row, 5/8" BSP
Im going for the 16row 5/8" one but BBperformance use the 13row one i think.
If your interested please sign up in the usual way.
Should be able to get the 16 row for £38 + Postage and the 13 row for £34
infront of the standard rad.
I own a Mk1 16v and we screw it into the front cross beam infront of the standard rad.
You can also get things that let you mount it on the actual rad behind which mite work for you.
Im sure you can think of something!
Any Mk2/3/4 owners that use oil coolers speak up!
They are real Mocal.
No sandwich plates, tho im talking to suppliers about them.
The oil coolers are from rallydesigns.
Andy
Andy
Why are they nearly £100 cheaper than mocal ones on say demon tweeks, ebay, k-tec etc..?
I will buy one if quality is ok.
im only currently selling the "rad" bit.
The hoses and sandwich plate you will need to source.
I am working on some push fit hose bits from tweeks, going to try and find them cheaper etc and just use hose camps to fit them.
I know no one that can make up hoses for me.. £60 someone told me for hoses.
£60 + £25 + £40 = £125 which is about what the kits cost else were.
