modding coilovers
Car  clio 172
quick question lads, shoot me down if its stupid,
but could 52mm coilovers be slightly modded to fit 54mm
cheers
Ben
Matae simular thread was put up yesterday... have a look in the suspension section. was in relation to putting non cup coliovers on a cup and modding them
had a look at that thread mate but surely its easier to make 52's into 54's, sounds complicated in the other thread
52mm hubs are also narrower, it's not just the hole spacing that is different
Indeed, which makes it a lot easier to put 54mm coilovers onto 52mm rather than the other way around, as its easier to slide in a shim than to mill off a section
both inherently possible though and nothing like the problems with the cup and non cup ones in the other thread as its so much closer to begin with.
Still makes more sense generally to just get the right ones in the first place though as a rule of thumb, as even if you happen to have some 52mm ones, they can always be sold and buy secondhand 54mm instead etc.
but 52mm are for smaller engined models which run a narrower track too, so it's going to throw out everything, camber would be positive for a start.
Don't bother
Don't bother
Oh I agree totally, although you can obviously make sure that when you elongate the hole you do it in the right direction to correct camber, but its just not a good thing to be doing at all generally, fat better to just have shocks that fit.
By the way though, surely if you put the narrower track shocks on the wider track you mean its going to push it negative not positive, like it adds negative camber when you put williams arms onto a valver with the valver shocks still etc.
don't really care. it's still wrong
If you had a 1.2 clio and wanted "lowz" and "mad camba" you would care, 54mm coilovers and some shims would have you cumming in your pants then, lol
But I cant see you or I ever falling into that category or wanting anything to do with cars that do, lol
Don't bother
Cheers for the advice. I was just being a tight f**ker realy, I'm not looking for mad lows, don't car what it looks like, purely looking for handling gains, will jus bite the bullet an buy the proper size
cheers
