Monaco 172 Track Car
I've found heat guns quite effective in the past, but I guess some work better than others. Petrol ftw when cleaning it up though, works better than anything else.
This morning was a fresh day, a fresh head and a better idea of what not to do
I started by getting the blowtorch on the roof sound deadening. By god this made it so much easier! If you're going to do this yourself, a nice robust scraper and a butane blowtorch is perfect
View attachment 1803334View attachment 1803335
With that easily tackled I turned my attention to the rest of the sound deadening that I didn't hit beforehand
View attachment 1803336View attachment 1803337View attachment 1803338
All the sound deadening out
This is when I started to test petrol Vs isopropyl 99.9%
Petrol wins. It was 50x quicker, that's not an exaggeration. That was one small wipe with petrol on the left🤣
Absolutely blitzed through the rest of the cleanup. I went through at least 5 rags cleaning all of the glue off. I then took out as much of the bulkhead matting, I wasn't going to at first... But then bad side of brain took over
Big bag of sound deadening removed
Guess the weight, this doesn't include all of the chunks Hetty hoovered up. I reckon she got the best part of a kilo out
Tomorrow I need to clean up some more stuff, remove a load of unwanted and un-needed brackets, take the side skirts off and then give it a clean ready for 5am Tuesday morning
Itll get the arches welded up, rolled, front jacking points welded, interior painted, roof sorted, roof scoop painted (and fitted), and I've made the last minute decision to remove the aerial so I'm hoping if it's not too much of a pain they can weld up that hole and paint the full roof
Whilst it's away I'll still be buying parts for the engine build in the background. I reckon it was a CV boot at Croft
Either way I reckon I'll get 2 new shafts, or recondition 2 I have in the garage
The next time you and I see the car it will have less orange
You got a lot done, impressive! Whereabouts are you having the welding and paint done? Hope it all goes well.
I've seen a few people cut the floor out and tigerseal a carbon sheet in. Looks racecor smart, prolly 10kg saving too.
Aye I could do that afterwards, I need to make some polycarb pieces to cover up the seatbelt holes
I've got the door cards but there will be a big gaping hole where the seatbelts go. I'll see what it's like when it's painted
No I asked @Louis to cut the boot floor out of his 182 before he scrapped it and he didn't cos he's a c**t
Happy I Love You GIF by Warner Bros. Deutschland
Few jobs tonight. Took the skirts off, which revealed how bad it's got
I took the rear wiper off too, I've been stripping all the unnecessary stuff out that doesn't get used anymore, speakers and radio will be next
Gave it a quick wash and cleaned/blew all of the inside out so now 99% of the crap is gone
Locked and loaded for tomorrow
Yea box section up each sill, I looked a few years back and you would need some brackets welding onto the box section so it can bolt on unless you just weld it direct to the sill/floor.
They make jacking the car up so much nicer, just shove the jack anywhere and never worry about folding the sill up.
Always fancied doing a rally jack setup with tubes in the cills for stands/jack, and quick jack points front and rear. Be super easy to get full car in the air.
I looked at air jacks for hours one night for the VX, would love to do it but its a lot of work. Would probably be alright in a Clio with a cage. Air jacks are just so flipping cool 😂
