More Photo Editing
  Mental 172 Cup
Hi all,
Ive recently come back from Dubai and its an amazing place to photograph due to buildings etc. The only problem is because of the heat (50degrees) and the humidity you tend to get a haze that tend to ruin some amazing photographic oppourtunitys but giving a misty effect to certain photos.
For example:
As you can see the haze has kinda ruined the photo and I was wondering is there anysort of editing you can do to make the photo look any better???
Luke
  Cupra
You were shooting towards the sun which will reduce contrast so you can try boosting that.
Black and white is normally a good fall back if all else fails.
I tried the second one for you just playing with the curve.
Hixle
Hi Kiss Luke E****
  981 Cayman GTS
Slight bit of contrast should do it mate, I found the same when I was out there!
Btw, snap ;)
  Mental 172 Cup
thats where I got the inspiration from ;) yours seems to be shot at the same time of day but a little later then mine as the sun has settled slightly! I think im going to have to go out there again in the winter when its less humid and have a go then! :)
  Oil Burner
My effort.
The haze on the l/h side is just a bit strong to completely get rid of it.
Side effect has been to remove the nice amber glow of the sun. Could sort this in photoshop.
  Mental 172 Cup
that looks good I like that! what programs do you all use to edit???
by the way if it makes it any easier I have a RAW file of this image!
Hixle
Hi Kiss Luke E****
  981 Cayman GTS
Haha any excuse to get back out :D
The above edit is spot on!
  Oil Burner
I just used Lightroom, download the trial and give it a go.
The clarity slider, contrast and fill light were the 3 most effective changes i made.
